Well that sounds as I expect - I'm still getting around -80dBu noisefloor at typical settings, which is around +17dB gain now - that is around 12dB of eq makeup and 5db of general gain.
No problem at all - output atten is still at around 1/2 way. The pad is engaged and the input atten fairly low at 1/3 of the travel so as not to push the front too hard.
Not getting any audible hum, as I would expect at those measured noise levels.
There is more hiss now - quite a bit going on in those mid freqs, so it is to be expected.
Also, even though the eq is driven from a low Z, the tone stack is quite high Z, with 500K and 1M pots in there. It would probably pay to scale down the high value pots and so on - likely not on the cards for me, though.
Next up - the 'drive' section.
A 6BJ6, my favourite little pentode - it has a lot of push for such a little guy using next to no heater.
Can pass a fair current too - I've used it at 15mA total plate/screen no probs.
The input to this is the tone stack, which ends in a 'Pre' pot of 1M with attenuation all the way to nil.
So that's a fairly hiZ driving source to it's grid.
I will bias it up fairly cold, so as to take a goodly voltage swing, maybe 10Vpp or so before grid limiting. Gain will be low-ish and the output will likely go to a divider then to the 'Drive' pot at the front of the line amp.
Twists will be a 'mode' pot for transitioning smoothly from triode to pentode mode as well as anything else I can do - thinking some messing with the screen in 'pentode' mode.
The idea is for maybe 24dB of gain, then to divide down to 10dB or so before hitting the line amp.
I'll see how it goes.
So far, so good
