Redd 47 Pre with Drive+EQ DIY
Still banging away on the pentode ..
It has a gain varying from around +32dB in full pentode mode, down to around +24dB in full triode mode.
Now that's a lot to throw in the path, especially when you have some pots'n'switches hanging off the plate and screen - hiZ = lotsa noise!
After trying a few things, I ended up using a pair of 2-core shielded + foil  as hookup for the controls.
I have the shield+foil grounded at both ends, in this case.
Now that's made a very big positive difference in the noise levels related to the control wiring.
Something like a 15dB improvement in headline noise, mostly at hum freqs but with some hiss reduction too.
With the pentode stage switched out, I now have my baseline noisefloor of around -82dBu or so.
With the pentode in +32dB I have a noisefloor of around -72dBu
So that's pretty good and should improve another dB or two when I have the controls mounted on the alu face plate rather than lolling about on the table :)
So - when dealing with hiZ, high gain -> shield + foil grounded is best!
That's a big milestone because I've always had big issues at the pentode gain stage with noise.
Of course, it's quite microphonic as one would expect! I may try some tube dampening rings.
The final checks are with pentode in, Redd 47 at unity gain with -10dBu line input
+32dB gain -> 'Drive' pot -> AU7 and line amp -> T-pad
with the T-pad at min attenuation and the 'Drive' set for unity gain at output
I get my nominal baseline noisefloor of -81dBu
Same thing but with the t-pad turned way down for 'strong atten' and the 'Drive' way up, even better at -82dBu.
So that's a wrap.  :)  :)
Now I have a working 'max pentode gain' scenario, I can go forward and figure what fixed atten to put after the pentode.
THEN, re-connect the EQ circuit and that's the hard part done.  :)
Before adding the EQ back in circuit, I put in a 'eq bypass' switch - it has a 12dB pad in the bypass position to more or less match a typical eq stack loss.
I also figured about 20dB is the max gain I want from the pentode, so I put a resistive divider on the plate output.
Once I put the eq back in circuit, I get a 'worst case' noise floor with flat eq of -74dBu with an output set for +4dBu. (which is close to the max my Motu test rig can handle).
That represents around +14dB overall gain xlr-to-xlr, not including the +12dB EQ makeup applied.
I think I can tweak that by maybe 3dB more once I button up the unruly front panel wiring.
That's about as good as I can see myself getting with all the undisciplined wiring and such, and is actually pretty good.
It remains more or less the same regardless of the setting of the pre-line-amp 'Drive' pot setting and post-line-amp 'Level' t-pad.
The Orange86 module (redd47) feedback-attenuator 'Input' control does not affect the noisefloor at all, but does strongly influence the THD amount and makeup.
There is obviously a 'sweet spot' with the 'Input' and 'Drive'/'Level' controls for output level, noisefloor and THD.  :eek: :eek:
This unit will drive my monster limiter, the pmSix61 which is quite happy with high input levels and has a very low self-noise.
So I expect that with an average output at around +4dBu, I should wind up with a noise floor of -77dBu for this unit which is pretty respectable and with the limiter after it, should remain around that level.
More or less.
So - that's the noisey bits done.
Next to finalise the line amp 'Feedback' network - I may well retweak the gain staging once I see the effect of this control.
Then back to the Orange86 module to add the 'Squish' pot and tap into the LPF to extend into my 'HiCut' rotary.
Next stop, I'll also have the front panel in place - I need that to 'get real' for the final lap.
I'm pretty sure this guy will be worth the effort in the end  :)
Still haven't done the front panel  :)
But I *have* been playing thru this guy for a while now at the bench.
I truly think this is the best sounding preamp for the egituar I've built to date. It really does sound the closest to a tube amp set to be basically clean but with a little crunch in the bottom end and mids.
At the stronger crunch end, I probably could use a little bit more filtering of the top end to get rid of a touch of aharmonic sounding distortion in the 2K-5K region. But it's not too bad even at higher crunch.
Not a hint of the usual 'hissy-fizzy' business that overdriving grids gets usually gets you - classic 'boogie' preamp territory. This is way more like a marshall - visceral mids and growly bottom ends, with the tops mostly pure.
I'm in 2 minds - either to button it up as is, or to go for a better EQ, like using Ian 'Ruffrecords' EQ pcbs to get more control.
It's sounding so good I think it deserves the 'ruffrecord' eq treatment to really tune things up.
I attribute the sound to  :
i) pentode first stage
ii) 4 stages of edcor and like traffos
iii) split PI
iv) strong pp output stage with t-pad after traffo
The eq+pentode doesn't do all that much - the thd is all in the front end, the 'grunt' in the back end.
I will say the 'lift' control is cool and so is the morphing 'pentode/triode' mode.
The 'shift' not so useful - prolly ditch it.
The 'feedback' was a bust - didn;t do anything useful - gone.
So far the hi-cut filter not usesful either - gone.
The noise performance is great - with strong levels being around 12db on EQ makeup and 12dB overall gain, I'm seeing around -76dBu noise floor 20-20K 'spl style' measurement.
That's on -84dBu 'loopback', so 8dB worsening - which is not bad at all.
Miles below the -60dBu or so where a gate starts becoming a necessity for good silence.
Due to  the excellent 4-stage HV pi-filter/regulator on the 'Orange86' (Redd47) module powering eveything, the additional pi-filter de-coupling of each stage's HV and also the 40KuF (on 2.5A) heater pi-filter.
As well as foil+shielded front panel wiring.
So - to splurge some more cash and time. Or not - that is the question!
If I followed my heart, I'd put in Ian's Helios style eq.
That's what it deserves. If the noise performance wasn't up to scratch (which I fully expected), I'd not bother.
But it is. And Ian's Helios Eq would make it a truly unique box in my collection.
Oh well - there's worse things in life to weigh up  :)
Back again on this project after a long absence ....
I just finished this one. Here's the final inside pic.
    144.6 KB
It is performing really well - very quiet despite the 'prototype' level build values  :)
And it has quite a lot of places to dial in/out gain.
Doesn't really do crazy over the top stuff but many shades of harmonic distortion. It's a very classy sound.
My absolute best yet - getting smooth crunch is best done imho with gentle gain staging across many, MANY tubes, transformers and filters :)
The EQ is actually quite tame but does a lot of unexpected things - which can be fun.
Frequency response is all there - no real issues to speak of.
So - perhaps a little more time to tune the EQ but prolly this guy goes into my music room today!
I'll be using it with my pMSix60 Limiter with a cheap SDC tube mic as well as others.
AND for DI the guitar/bass. I have a Bass VI which I plan to use with it - that will really shine there I think.
bfn
AlexC
    81.7 KB
