tommypiper
ruffrecords said:You could add a switch to connect the input of the second stage of the classic either to the EQ output or to a line input transformer. The EQ input would then be unbalanced high impedance (just what the EQ likes) and the line in would be 10K balanced.
Excellent, that's what I was thinking. Will the Classic 10k attenuator and HPF work with both the line input (with input transformer) and the unbalanced EQ input? Does that change the load on the EQ from 1M to 10k?
And no problem connecting the EQ to Classic with unbalanced cable...? Use screened cable, screen connected to one end...?
