Reddish 500 EQ
Just completed this build. I purchased a set. I was able to get one running flawlessly however, the second one.... nothing. Passes signal in bypass but when active, I get nothing. I hear the relays going off. Can someone lead me through where to troubleshoot? I appreciate it. I haven't not tested voltages as I'm getting nothing to start. Any help would be great.
Testing voltages would be the place to start.
If voltages are good, the next thing I'd try is switching it to a different slot in your rack to see if that is the culprit.
These steps help us rule out the obvious (yet easy to overlook) variables. You'll want to do that first before we go hunting in the circuit.
The good news is that you have one unit running, so we have something to compare it to. Please report back once you've done the two checks above, and if the problem persists, we'll move on to troubleshooting the circuit.
Set your multimeter to measure DC voltage. Place black probe on the 0vdc pad on the edge connector, being careful not to accidentally short to either power rail. Then place your red probe on pin 8 (top right) of the op amp, where you should read approximately +15vdc (anything within roughly a 10% tolerance is within the realm of what we expect here, we're only worried about it if it's really far off). Then move the red probe to pin 4 (bottom left) of the op amp, where you should read approximately -15vdc.
