nielsk
They are not backwards, both sides are wired in series. There is a U pad on the input (2x 4K7 and one 200) and the secondary has a 4k7 across pins 7&10
nielsk said:They are not backwards, both sides are wired in series. There is a U pad on the input (2x 4K7 and one 200) and the secondary has a 4k7 across pins 7&10
nielsk said:I have found something very promising, there appears to have once been a producers desk that had a duplicate set of oscillators in it that was removed and the wiring hacked off. The bridges across all the busses is still there, un-terminated. Of course, very difficult to get into with the iron, but I will either remove it or ground it.
I have gone through the frame & routing module wiring completely, there appears to be no ground loops. One lead goes from the B- buss bar to each module, and hits all audio grounds and internal module shielding. The module case and all external cable shielding goes to the frame, no connection between them.
nielsk said:It is just about all back together, should be firing it up & testing today / tomorrow.
While I can't see how un-terminated resistors on the mix buss bars can be a problem (other than acting as a tiny antenna, how can a resistor not connected to anything cause a problem? there are many un-used rows of resistors for various options, as well as un-used rows of ties to the busses) I do believe that the groups of resistors that were tied together and not terminated are the problem. Feeling very optimistic....
My current line of thinking on the 10468 as a line input is that the 208 amps can't take much level, it is stomped down to -29. Maybe it was determined that it works better to do this by the input pad then by attenuating the transformer output? Or just sorting through the various options to get the right level?
In my experience, as long as the transformer can take the level, it sounds better to attenuate level after a transformer than by padding the input, are there cased where this is not true?
ruffrecords said:nielsk said:Frame is back together in it's new home (still under construction!)
I will measure at the routing module connector between B- and audio ground, but it ties inside the routing module (clearly shown on the schematic, on the 1993 module pin E1 is tied to pin H1, and on the 1985 unit pin V1 is tied to pin A1)
All the B- runs from the edge connectors to a (maybe 1/4 " square) copper buss bar that runs the length of the console, and the buss bar is tied to the chassis.
All the shield lines tie to the chassis.
I need to fully explore the path the audio (referred to as "audio B-) grounds run.
I think he said check between B- and CHASSIS which is not of course audio ground.
I don't think the B- bus bar should be tied to chassis at any point in the console except really close to the technical earth terminal. Check out this Neve missive:
