Helsing
I want to use an LM317 to regulate a DC voltage between 60-70 down to 48v without the need for a heatsink. I say 60-70 because I want to accomodate variations in mains. I am using a 22-0-22 power transformer.
I will be powering 1 to two microphones. 40ma current capability would be sufficient. Indicator Leds are powered from a separate source.
Im thinking I should add a large series resistor between the filter cap and the 317 to limit the current into the regulator. Im thinking V/I=R 70/.040=1750 W=I^2 x R= 2.8watts
1750 ohm 3 watt resistor.
Am I on the right track here?
Helsing
Helsing
