I'd add to this really useful topic some things I've done in the last years:
1] cleaning pushbuttons
All you need is a syringe and some contact cleaner fluid.
There are small linear openings at the rear top of the switches.
2] Transformers repair
I've had a faulty line transformer in an input module:
the primary's connections [6 and 8 are the interesting ones in input module] to the pins
were lost.
Repairing them is really easy, all you need is a little tip on your iron,
positioning the transformers so the solder will flow, thanks to gravity law, towards the wire, and a firm hand.
[as you can see, I've also cut/melt some of the plastic on pins 6 and 8, to have the wires nearer to the pins]
After that, the transformer started to works perfectly, measured also its winding DC resistances, completely in specs.
3] Adapting a 961/962 meterbridge
In
this topic I've documented how to 100% use the features of a 961/962 meterbridge in a 169/269 console.
