RuudNL
A friend of mine has a non working Rode K2 microphone.
To repair it, a schematic diagram would be very helpful.
Any hints?
Any hints?
Gus said:The schematic might still be on a hard drive in an retired PC in my basement
micaddict said:This GDIY thread is over ten years old:
http://groupdiy.com/index.php?topic=12073.0
And Gus was there, of course.
I also need to fix this mic and I’m looking for the value of the resistor on the PCB where the lends are connected (R1). I found a schematic, where the value is written down as 3 G. Does it really mean 3 Gohms?I will look for it later today
EDIT from the wayback machine
http://web.archive.org/web/20100811083829/http://www.diyfactory.com/projects/gus/ntkmods.htm
Note I would now leave all the caps alone (maybe I made it worse). Maybe change the electros if you feel you need to.
Note the K2 marking on the PCB.
I changed the 6dj8 type tube to a 12ay7 (changed the heater wiring on mine) Before this I tried a number of 6dj8 type tubes.
Not much changed if anything sound wise.
Someone should check if I traced the circuit correctly.
I think it is clever how the voltages are set up.
