dirty1_1garry
J175 smashing even more)Spencerleehorton said:Could you try a J175?
Best way to add “active” bypass, when signal will pass thouth preamp/amp is ground detector input. Same principle as in 1176, yes. That mode will allow to distort preamp (as it has headroom just about 2.5Vrms) for additional coloration.Spencerleehorton said:Quick question about putting a bypass switch on here.
As this circuit is basically a 1176 rev d can I add a switch into the GR control amp circuit as per the 1176 to bypass compression?
What I mean is, is this the best way to bypass the compression?
Spencerleehorton said:Also I’ve found a P1086 p channel jfet is this any good compared with 2n3820?
Are you able to simulate Gary?
Vac11 said:Thanks dirty1_1garry!!! It is nice info.
Do you think its possible to public full resolution schemo from you LT Spice project? It coul be helpfull for us who will try this circuit...
Vac11 said:Tnank you very much. Is there any reason to use 2n5088 for q12, q13 and q11 instead of BC550C?
Spencerleehorton said:Just to note my only difference in cap values so far is 6.8uf rather than the 4.7uf in the driver amp.
I was told some time ago that as long as your fairly close to the desired value but higher should be fine!?
