Hi Jarno ,
I did some experimenting last night , disconnected the internal LFO on my CE-5 , wired it up first to the 2206 , wasnt great , output voltage drops off in the low ranges so it couldnt do the job properly .
Then I hooked up my Feeltech arb gen , the many different waveforms created interesting sounds and gave infinate variation over the standard saw wave LFO built into the pedal ,If you go much beyond the usual frequency range of the the built in LFO you either end up with imperceptibly short delay of good quality in one direction vs longer delays where the sound almost becomes unrecogniseable to itself
Driving the LFO waveform input(with depth pot wiper disconnected ) with 4,5,6,7 volts at low frequency and the Ce-5 held up very well ,it allowed a much stronger 'effect' than the standard onboard LFO which could only manage about 4 volts swing ,being able to drive the effect deeper means when your recombining it with the clean original sound in parralell you need much less effect return level ,so this would seem to improve the noise overall .
There was some residual dc voltage at the input due to the transistor up ahead ,so I simply dialed in approximately the same offset voltage on the arb gen output , Im not sure if thats correct or not , but in any case I swept the offset down to zero and it had no effect on the sound .
Anyway it seems like a plan to box up two CE-5s and make the LFO path accesible on both ,
I have my eye on a second old model Ce-5 , and my brother also wants to convert his to dual if he can find a second unit .
I have a pair of die cast boxes suitable for the project , I could in theory run all four units synced from the 2 Feeltech arbgens , any degree of phase shift I want between channels , any wave form ,
thats bound to sound very tasty on the right source material
I see Behringer has released a new modular analog synth ,no doubt packed with Cool audio's silicon , surely it wouldnt have added much to Uli's bom to make the 'June' a proper stereo implementation BBD chorus , the penny pinchers won again it seems and their trying to short change the customer in the process , its a bit of an imbarressment for the company to be honest, a wasted chance .
