S800 Support Thread
Can someone help me with wiring this power transformer? It's an Antek AS-0518 Here's it's spec page:  http://www.antekinc.com/content/AS-0518.pdf
For the primary, I'm in the U.S, so it's in parallel right? Meaning I tie together the two reds for the AC hot, and the two blacks for the AC neutral?  What about the purple (extra static shield) Would I tie that to the Chassis?
For the secondaries, parallel again? Tie the middle blue and green wires together and the outer Blue and green are my secondary leads to the power supply pcb?
Correct on the primaries
Secondaries are wired in series, tie the central Blue and Green together - make sure you are not shorting out one of the secondaries!
This combined join gfoes to 0v/Chassis ground as illustrated bit 'ct' in this diagram.
http://3.bp.blogspot.com/-PXkB2Ay6OHc/UEHP-rOgR3I/AAAAAAAAD_U/YeqEd1jmXlI/s1600/dual-regulator-power-supply-circuit-300x247.gif
Hi Junk, TDR and Flag
I have got a quote from my PCB plant, delivery to me is 10-14 working days, and shipping to you is 2-3 weeks.
So about a 6 weeks delay before you get the boards.
Is that OK with you? If so, I will order them and put up a White Market thread as soon as I receive them.
Regards, Peter
Ah,
Just finished 4, so I guess I should order another 4 because they're frikkin awesome.  Junk,  if you're just ordering 8 to get past the minimum, let me know. I'll take half of those if you want, or maybe I can add 4 more Peter? Hmmmmmm
Jon
Thanks Peter! Jon,  I was just originally asking for 8 to get the min # up, but after some thought it's gonna be a whole lot cheaper to do 8 at once than to do 4, fall in love and do another 4 later.  ;)
