I just finished my SA3A yesterday and it worked right away
Thanks Mike for putting this project together - it was really straight forward and the compressor sounds awesome!
Also calibration was a breeze with your step by step instructions and stereo linking works flawlessly! I adjusted the HF mod to add 5db of compression
@ 15khz and despite others here finding the HF switch to be a waste of space on the faceplate I find it a great feature to have!
Since the extra compression starts smoothly above 1khz I love how this can kind of soften out the high-end a little and keeping everything up to 1khz
round and full! Makes it even more versatile to have a switch for this on the front!
In terms of noise - I haven't measured yet but even though there is an audible noise after turning up the gain more than 8 - I think I could live with it
since at that level my speaker would already be blown
The noise is not a low freq. hum - it is more somewhere between 1k and 5k. I tried rotating the power xfmr and putting a mu-metal shield between it and the pcbs but it didn't change anything.
The funny thing is that the channel that is further away from the power xfmr is even a little noisier than the one closer to the power xfmr.
I probably have to change the wiring at the XLRs for unbalanced use (since the SA3A is used on unbalanced inserts of my console only), because up to now it is still wired for balanced use.
The other thing I encountered when - with no input signal - turning the input gain all the way up to 10 and crank my speakers up a little more is a slowly oscillating low level noise...about 1 rotation a second.
It reminds me of how my soldering station sounds when it is up on temperature
So these are the only two things I would try to optimize somehow - if anybody has any idea - please let me know!
