monobass
monobass said:Hi,
Has anyone done a sidechain HPF mod on the SA-3A?
So I guess no one did? Is it viable on this unit? Am I asking a dumb noob question? ;D
monobass said:Hi,
leitrim_lad said:Hey there, im just wondering if you could help me, i seem to be having a problem with one of the channels. the right hand side channels keeps seeming to cut out every now and again.. i could be in the middle of tracking something and next thing it just goes, when i have to turn the gain nob up nearly full it kicks in again and starts to work for a while. Any ideas on what it might be?
Thanks in advance
miketeachesclass said:I'm done stuffing the boards, and am ready to start wiring.
Is it critical that the 18g wire from the IEC inlet to front panel be shielded? I've got a ton of 18g wire, but none of it is shielded. I've also got a ton of 22g shielded cable. I'm planning to mount the toroid on the side of my case, unless someone has a compelling reason I shouldn't.
Mike
ruckus328 said:miketeachesclass said:I'm done stuffing the boards, and am ready to start wiring.
Mike
22 Gauge wire is not safe for the mains wiring, it should be 18 gauge minimal. You don't need shielded wire there, however since this is mains AC there is a very high likelyhood it will cause hum in your unit depending on how you wire things.
No issue with mounting transformer on the side, just be sure your side panel has good ground connection with the other pieces of your enclsoure.
miketeachesclass said:Thanks.
Is it just me, or is it hard to find 18ga shielded cable? Where is everyone getting theirs?
I suppose I will probably just try it and run the 18ga wires along the side of the case, as far away from everything else as possible.
Mike
Mike
tom f said:I noticed a significant high frequency boost (a little bit like an exciter)
and loss at bass frequencies in both channel when comparing to bypass.
The input level on Gain on 10 (when in 30db gain mode) is to soft for compression (no Gain Reduction audible and visible)
although Peak Reduction is on 10 too.
Do you know a solution for this?
