Hi, I bought a SA-3A kit and a front panel from Serpent audio.
For the PCB and components, no problem, except 2 resistors that were missing.
The front panel is also nice. But informations on the website are not exact.
As Serpent audio suggests the use of Modushop enclosures (it is said that they are guide holes compatible with modushop), I bought one there., " Modushop 2U black Pesante". Unfortunately, WARNING !! I encountered two major problems with these enclosures.
1) On the Serpent audio front panels, you can see on the back face 2 pre-drilled mini-holes on each side (left / right).
Which little hole is the good one to enlarge for modushop ? The upper or the lower ?
I wrote to Serpent audio by email, I never get any answer
2) worst : when this nice front panel is populated, there is not sufficient space on the modushop enclosure !!
In fact, they are bends on each iron covers. It probably helps for maintening the rigidity of the rack but it eats space vertically ! It hinds around 5mm or even more, up and down on the front panel.
So in fact, modushop racks are NOT compatible with this project
![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
In order to have sufficient space, you have to cut those bends on each iron cover, which is almost impossible to do it by yourself properly with a circle saw. And the metal is very hard. Then after, the enclosure is ugly and not perfecty closed. :-(
Is someone encountered the same problems ? Some suggestions for europe about compatible enclosures ?
Which pre-drilled holes are the good ones ?
Thanks for your opinions and suggestions ;-)
