Stone dead thread, but for potential future builders here's my little contribution.
After getting the new proper toggle switches, finally ready here. No major issues. Had the 'usual' hum on the right channel. Cranked the volume, put headphones on and started fiddling with the cables. Trying to shield the pwr xformer didn't do the slightest for my unit. Having bought too narrow shields for the power cable forced me to put them (one from the IEC inlet->power switch, the other from the power switch->power xformer) in separate shields (wrapped in shrink tube) which turned out to provide the solution. Because when I separated them the hum went down 10-20dB to barely audible. Seen on the pic at the bottom (right side of unit), the two tube wrapped leads form a square'ish pattern.
Waiting for stereo matched T4Bs from Kenetek, but tested with a single T4B from my LA2, hence the empty sockets.
I decided to trust Harpo that I'd be ok with 1/4W pots, so used these:
http://www.mouser.se/Search/ProductDetail.aspx?R=RV24AF-10-15R1-A100K-3LAvirtualkey14860000virtualkey31VJ501-F3
After the goof mentioned earlier, with the 14 switches I ordered these:
http://www.mouser.se/ProductDetail/NKK-Switches/M2012SS1W01-C/?qs=sGAEpiMZZMvudeGI7i40XOVezHpYSFdNLOdlzCspGKk%3d
Couldn't find shield for the power cables by the meter at Mouser so bought at ELFA in Stockholm:
http://www.distrelec.biz/en/shielding-braid-mm-alpha-wire-2171/p/15508676?queryFromSuggest=true
Got a cheapo Molex crimp tool at eBay:
http://www.ebay.com/itm/171762703269?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Worked fine but, as mentioned by others, that part was the least fun..
Other info I've picked up from this thread:
- Case from Collective cases
- Used nuts as spacers betwen case and PCBs (T4B fits under the hood)
- Dremeled the inside of the face plate around all holes for switches/pots
- As described in the schematics, did not connect pin 1 on the XLRs (though the shield of the wire is connected to the Molexes)
- Spaced the larger transistors from the PCB
Also, the XLR connectors I believe are not mentioned in the BOM
For wiring as in the pic from my build, these are the wire lengths I used:
L channel
Input (XLR): 8.5cm
Output (XLR): 7.5cm
Classic/mod: 28cm
30/50: 34cm
VU display: 40cm
Comp/Lim: 25cm
Bypass: 42cm
HF/Flat: 29cm
Gain Pot: 20cm
Peak red pot: 30cm
Link: 31cm
VU meter (from J11): 43cm
R channel
Input (XLR): 11cm
Output (XLR): 8.5cm
Classic/mod: 34cm
30/50: 43cm
VU display: 51cm
Comp/Lim: 34cm
Bypass: 53cm
HF/Flat: 20cm
Gain Pot: 28cm
Peak red pot: 42cm
Link: 18cm
VU meter (from J11): 53cm
As I only tested one channel at a time briefly I didn't get any impression of the sound, but of course look forward to getting the matched T4Bs, stereo trim the unit and start using it!
Edit: When ordering I missed that the component kit was stereo, so I accidentally ordered two stereo kits, which I noticed when building, two years after ordering, so...d*rn it I had to build yet another one.
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
It's ready tonight. Tested and calibrated. Had some time playing with it and wow I have to join the choir..these are good!!
