jandoste
jandoste said:and I will try the semi LM7912
Yes it was ST ! and the Psu works now !
Don't use ST LM7912 !
jandoste said:Hi Mike,
I gor two questions,
Firts I used the same switches and I would like to be sure the wires connection ? how ?
and the second question is for the the VCA's JMPs?
Niketouille said:Does a 67x34mm toroidal transformer will fit ? I'm not sure about it so I prefer to check...
This is this one :
http://www.electronique-diffusion.fr/product_info.php?products_id=1077
ruckus328 said:Umit, it's just a SPDT switch like any other. 2 of the pins are for the LED. They should all be marked on the switch, otherwise look on the datasheet for which pins are what, I don't know off the top of my head. The board connectors are all labeled, schematic and wiring chart in the build manual show very clearly what goes where.
VCA Jumpers - In giant bold text on the board is says refer to the schematic. There's a table on the schematic that tells you which ones to install, it depends on the VCA's you're using.
Songguy said:Hi all,
Anyone have the back panel cut out measurements on hand. I need to send them to John at par metal so can get my project going.
Many thanks,
Chris
jandoste said:Hi All,
I have a problem with the analog VU Meter. it does not move. Do you have an idea? I checked all wires connection and all is right !
sheadstedford said:Got a quik impedance question!
I got the tube stage at input unbalncing it at 10kohm going into the sb4000, thats 600ohm i understand.
Do i definitly need a 10k to 600ohm tranny or can i still use it stright wired from tube out to sb4000 input connector?
Will this damage the sb4000 in any way?
ruckus328 said:Do you have makeup gain?
ruckus328 said:Is the unit compressing/threshold knob working?
ruckus328 said:Did you install R111 (330R)? If you're using a 1mA meter (you probably are) it should not be installed.
ruckus328 said:Have you tried adjusting VR17 (5K Pot)?
jandoste said:No, I have no sound ! ???
sheadstedford said:So for the the 1ma hairball meter i should NOT install the 330r resistor?
Even though there is a little box for it markedon pcb?
ruckus328 said:jandoste said:No, I have no sound ! ???
One thing at a time. If you have no sound then why would you expect anything else to be working ???
So you're saying the unit isn't passing audio?
