sheadstedford
The tubes i have are 6n2 though not the ones stated in the advert. Schematic is the same though.
Is unbalancing the input a major problem then?
ruckus328 said:No, -12V rail should be -12V. Don't plug the PS board into main board until you figure out the cause. Not much to go wrong here, just a simple 7912 regulator. Are you sure you're probing the correct pins? Correct part installed? How much voltage do you have on the negative rail (TP15)? Maybe you have a bad regulator perhaps.
jandoste said:ruckus328 said:No, -12V rail should be -12V. Don't plug the PS board into main board until you figure out the cause. Not much to go wrong here, just a simple 7912 regulator. Are you sure you're probing the correct pins? Correct part installed? How much voltage do you have on the negative rail (TP15)? Maybe you have a bad regulator perhaps.
Thanks Mike,
yes, I'm sure the pins are correct, and parts too.
- TP 15 = 28.6V
Is it correct?
cheers,
ruckus328 said:What VA transformer are you using? Do your other rails all have correct voltage?
I changed the 7912 and I got the same Voltage(28V)ruckus328 said:Again, look on the schematic, negative rail feeds to Pin 2 of the 7912 (U22) through a 10R resistor (R182) - R182 acts as a fuse if anything goes wrong. If you're not getting -12V at the output of the 7912 (Pin 3) then something's wrong with either the 7912 or you've blown the 10R resistor, or bad solder joints, nothing else it could be. First thing I would do is replace both.
What voltage rating caps are you using on the PS?
jandoste said:Ok, what do you think that if I send -28V to the mother board?
ruckus328 said:jandoste said:Ok, what do you think that if I send -28V to the mother board?
I think you will blow all the IC's in the sidechain. Do not connect it to the main board until you've fixed the problem, it won't work, and you'll be causing even more problems. Just be patient, you'll fixure out where the problem is.
If you don't have -12V at the output of the 7912 then it is not regulating. If you're seeing (-28V?) on your -12V rail now then this is like the regulator isn't even there and a dead short. Check all part orientations in this area, and check with a multimeter for continuity and bad solder joints on all the parts in the -12V regulator circuit (there's only like 7 parts here). Somewhere one of these 7 parts is either in backwards, blown, or you have bad/cracked solder joint. Did you inspect/replace R182?
Measure DC volts across the two pads of C151 and also C158, let me know what it says.
Check correct orientation of D29 - the cathode should be pointing towards D30.
What brand of 7912 are you using? Is it the same as your 7812?
Some high res pics of both sides of the board might help.
ruckus328 said:Measure DC volts across the two pads of C151 and also C158, let me know what it says.
ruckus328 said:Did you inspect/replace R182?
ruckus328 said:Some high res pics of both sides of the board might help.
ruckus328 said:Umit, at advice of Harpo, put a temporary load on the -12V rail just to verify that there is actually a problem, it's possible the 7912 is giving false readings because there's no load.
Just temporarily connect a 1K or 1K2 resistor (1/4W) between the -12V rail and ground. You can do this at the power output connector (J14). This will put approx 10mA load on the 7912. Let us know what happens after you try this.
ruckus328 said:Shead, I'll try and look later tonight. Don't think you'll hurt anything grounding the negative input of the debalancing stage of the sb4k (aka tying pins 1 and 3 of xlr together).
Peronally though would annoy me though to have unbalanced input and balanced output though, might want to consider xfmr balancing the input of your preamp.
Curious what you're trying to get out of adding this though? Just color?
jandoste said:ruckus328 said:Umit, at advice of Harpo, put a temporary load on the -12V rail just to verify that there is actually a problem, it's possible the 7912 is giving false readings because there's no load.
Tried (with 1k) it and got -20V ???
ruckus328 said:jandoste said:ruckus328 said:Umit, at advice of Harpo, put a temporary load on the -12V rail just to verify that there is actually a problem, it's possible the 7912 is giving false readings because there's no load.
OK, with that resistor still installed how much voltage do you have between the - rail (TP13) and ground (TP14)?
Neil said:Jandoste, from the same thread Mike quoted there were some problems with St Micro brand regulators. If everything else checks out you may want to try swapping in a different manufacturer's 7912.
ruckus328 said:Hold the phone guys.......
Umit, did you ground your power supply like I instructed? Please read post above.
ruckus328 said:Also, check your wire going from the Power Supply Board ground to your Mains Ground/IEC Connector Roll Eyes
If you don't have a good connection here your whole PS will be floating. Make sure you unplug you mains cord first before messing around with your mains/IEC connector.
