David R.
Active member
Great, hope to see you at AES! Do you have a booth? I will look for you.
Might not be needed at all. (LPF set for 48kHz in 1st. inverting 2.5dB gain stage of the VU-driver) Not a critical part and not in audio path. Any cap in range 100pF-330pF with 0.1" pin spacing will do, if this stage doubtfully should oscillate.romplex said:Hi, i just started doing the sb4000 project , and im missing a 330PF ceramic capacitor @ c101, can i get any replacement or does it have to be a certain kind?
Thanks man. I have worked on Trident consoles, repaired and modified some channels, It still works apparently, so I do have some knowledge on op amps.Harpo said:Expect every opamp you tried in a wrong socket or with reversed orientation to be blown.ilvassa said:...as soon as I put in yust one ic, no matter in what position, nor what tipe of ic I do put in.
For usual there is no 2nd chance after powering on with parts fitted wrong.
You have to put the correct opamp in its correct position with its correct parts orientation.
In this build you have 3 different types of opamps comming in a DIL8 housing, - single bipolar NE5534, dual bipolar NE5532 and dual JFET TL072 - and the chips pinout and function is not interchangable.
funny counting: 'VR5-7-8-10 ', 'but 3 of them', 'measure 9.1 and 8.9'sage said:i am having an issue with the trip pots for VR5-7-8-10 the 10k variable
I am pre-trimmed all the other pots but 3 of them don't get to 10k - they measure 9.1 and 8.9 when at the max turn
so they are within specs (25% tolerance)I have double checked the part number for the manufacture and they are supposed to be 10k
You can use themCan I still use them or shall I get other ones?
sage said:Is there a possibility this migth be a bad meter or is there any suggestion on how to solve this issue?
