Harpo
Link at reply #1285 from pg.65 seems to be working ?justinvm said:All the links online are all dead.
justinvm said:Can someone please upload the SB4000 schematic.
I need to know resistor / jmp values for the dbx202c gold can VCAs.
JMan said:I’m still building this project. I got in on this late, so I’m just finishing up stuffing my boards. I also have some pretty basic questions.
First off, and I think there may have been some earlier discussion of this, but I can’t seem to find it now: has anyone got a good way of mounting the transformer without having that awful bolt head on the underside of the case?
Second, with regards to the trim pots, are there pre-trim values for all of them? I think I located all of the values listed on the schematic, but that doesn’t cover every trim pot on the board. Are the others purely for adjustment after the fact and don’t need to be pre-trimmed? (I think I did a bad job of wording this question, but I imagine you will understand what I’m asking).
Chrome Heart said:If you bought the kit. the trimmers in the VUDriver circuit have been replaced with resistors. Except for VR15, which is the Bargraph adjustment. Replaced trimmers are VR11, VR12, VR13 and VR14.
which meter? Reduction or bargraph?oscarat50 said:I can't calibrate my VU meter properly. It's getting the signal too loud and I can't turn it down using Vr15. I bought the kit with the resistors instead of the trimmers. Any ideas on how i can fix this? Thanks
Make sure the bargraph isn’t installed upside down.oscarat50 said:The bargraph
It shouldn't, unless the wrong value is currently installed. Are you sure the test signal is 1.228vac?oscarat50 said:It works as it should but the input signal to the meter is too loud. It's installed properly. The only thing I need is to reduce the input signal to the meter, maybe the calibration pot needs a higher resistance?
