Hey felix, I tried to upload it but it’s not going through — I think maybe the file is too big. PM me and we’ll get it sorted.
Here is a link to all the docs I have for this:felix1988 said:would be great man! i didn‘t find it yet.
Thank you!
critterkllr said:The dropbox links don't work for me so I can't get the build guide or BOM. I have a working SB4000 that I'd like to swap VCAs in. I'm removing a pair of Quad VCAs to a pair of DBX 202c's. Do I need to modify anything to get them to work correctly?
Bowie said:The schematic has a chart on the left side explaining what changes to make when using the DBX cans. It's pretty simple.
If you haven't found it, then here's a link to my dropbox that should work;
https://www.dropbox.com/s/ltxznsz09y02t8j/SB4000_schematic.pdf?dl=0
JMan said:Did you try Blackdawg’s google drive link a few posts up? That works and has everything you need.
I think you’ll need to modify some things to make the DBXs work, but don’t quote me. I’d take a very thorough read through this entire thread, as it was definitely discussed at some point earlier on.
Any chance you’d be willing to part with the quad VCA boards that you’re taking out?
critterkllr said:Thank you both. I didn’t realize it was in the schematic at first. I’ll need to wait until I’m at a computer since it shows up pretty blurry on my phone.
Will definitely sell the quad VCA’s if I end up preferring the DBX’s more.
Lordward said:Great stuff. So, I wired it all up and did the calibrations. For some reason my Bar LED is not working. No blink, nothing. So I was not able to calibrate this. Everything else went well and the unit sounds very promising so far![]()
had the bar graph in upside-down. Now it lights up. Checked it on a mix and it's always in the red in both input and output on a mix that has 5 db headroom. Normal?
I'll have to wiggles some things around to see if I can get the bar meter working.
One last question: There are so many trim pots and I find it strange that in the calibration I did not have to touch all of them, specifically the 2 on the VCA boards...what am I missing?
DW
oscarat50 said:Hi, I'm having the exact same problem as you with the Bar Meter always running too hot, did you ever get to fix this? Thanks
charleselmi said:Hi all, my first post in this forum, great place!
I'm trying to find which changes need to be made in order to install DBX 202X. On the chart in the schematic I can only find the values for the DBX 202 (black can) and Google is not helping much. But I've seen pictures of the SB4000 with 202X VCAs....so wondering if someone can help me out?
Thanx guys.
it's not.Bowie said:It's in this schematic, on the left.
Harpo said:it's not.
Have a look at http://www.thatcorp.com/datashts/dn127.pdf
calaverasgrande said:Couple parts clarifications if anyone is experienced with sourcing for this and can supply mouser cart or simlar?
I already own majority of the parts so I'm not buying a kit!
I can't pin down which relays to buy. The BOM doesn't specify package type or lead spacing. Just electrical characteristics for which dozens of items are possible fits.
The 2 pots for threshold and gain are 50K, 20%, 1/2W, 6.35mm but doesn't specify lin, log or reverse. I assume linear but you know, those crazy Brits love to put funny taper pots where they don't belong.
Also looking at the build guide they appear to be specific PCB mount pots of a type I'm not familiar with.
Also these 10,22,33,100pf ceramic COG caps are all listed as 100v? I have a ton of 50v, is 100v correct?
Not trying to blow up caps, but also trying to buy as much of this from Tayda as I can.![]()
