SE Electronics Z3300a
Looks like bad secondary insulation resistance.
On the DMM at low voltage it indicates well, but at higher voltage it is possible to make a short circuit between some turns
I noticed, when it began to "go bad" that moving the mic does "things" in the Tr aera...
So, wich Tr to remplace it and wich price ?
disconnect a wire of the secondary and interleave in series the DMM set to hundreds of mA, but this time to the good microphone, which works well
power the microphone
how much does it measure?
can't do it now : I will later, sorry...
But in case of big difference, will it mean I have to replace the Tr ? wich ref ?
if the secondary is wound second, last, then you're in luck, you can rewind your transformer yourself with the same number of turns and wire section
no way my friend !!! I don't know how and don't want to learn... ! enough things to do at this time 😅
this t.bone 2:1 must not be a "formidable" one > I could find a good one at a reasonable price I guess...
