leave 6.8k
in the circuits20KΩ for drain R : never seen that on a Fet...
ok...in the circuits
JFet+BJT+Transf
Rdrain=20k
a broken copper traceso we have almost tested everything... and I don't understand what's happening...
I culd redo a full volatge test on each component, before and after it ?
you must check the continuity of the traces with the multimeter and visually with a magnifying glassa broken copper trace
or a cold, imperfect solderso we have almost tested everything... and I don't understand what's happening...
that's just what I did : continuity with DMM is ok between all solders taht should be...you must check the continuity of the traces with the multimeter and visually with a magnifying glass
not only between solders, but between the terminals of the components and the soldersthat's just what I did : continuity with DMM is ok between all solders taht should be...
You could redo the solders though, to be sure. Maybe some oxidation?I just move all components on the audio board : no false contact...
I redid most of the solders at the begining of our process and cleaned the board 3 times with isoprop. alcool...You could redo the solders though, to be sure. Maybe some oxidation?
How does dc/dc measure against the good mic now?
