(-) of C3 must be connected to GND.tell me : c-C3 the 47uF in in serie between 4,7KΩ and R7 ? because I got the same voltage on + and -
it's filtering and also it's a kind of load
AHHH VOILA ! I think the 47uF rated at 35v (!!!) has blown away !!!!(-) of C3 must be connected to GND.
it's filtering and also it'a a load
imperfect soldering
Very well!I don't know if you can see in this photo but there are actually two tracks connected to the capacitor which I "reinforced" with two resistor tails because the capacitor was moving a little... it must be said that this board is a little weak in places (for example the 1015 had a bad experience unsoldering-resoldering-desoldering-resoldering and the track is damaged > but it makes contact)
I soldered its pin "-" in the track where it should... I replace the 25v by a 35v to be "more confortable" so I just replaced itVery well!
so, did you solder the pin ( - ) of C3 to GND?
What 25v ?? More!!!I soldered its pin "-" in the track where it should... I replace the 25v by a 35v to be "more confortable" so I just replaced it
is the original circuit C3 is a 47uF 25v that I replaced by 47uF 35vWhat 25v ??
Not.is the original circuit C3 is a 47uF 25v that I replaced by 47uF 35v
It is the most important voltage filterNot.
470uF 25v
Put one of 50v
sorry : I have put 470uF 35vNot.
470uF 25v
Put one of 50v
If the audio part does not work again, it does not consume, then the voltage will be higher than 35vsorry : I have put 470uF 35v
Correctif C3 must be to ground (wich seems normal) R7 too because they are connected together by the "-" of the 470uF
Merci,Sorry Micolas but I've to go now : I have an appointment tonite...
I will be back on this pb of capacitor to ground tomorrow...
Have a nice evening & thank you very much
Hi!Hi Micolas, I've tried to retraced the audio circuit (see attached) let me know please if you see some mistakes.
I don't know the value of the 2 inductances L1 & L2 (can it be measured by DMM ? I don't think so...)
I'm about to rebuild from scratch this board on a bread-board so there will be no more doubt about soldering & tracks
