SE Electronics Z3300a
Update... so everything seems ok to you ?
maybe a little "tweak" : the 4,7uF tantal. could maybe be replaced by a "better" one ? it is on the signal path...
    145.2 KB
I noted the diagram (3 times and carefully !) and shared 3 images with you:
- the front and back card > BUT the back card (right) is flipped verticaly so that left corresponds to left, right to right (board-1)
- the same visual with the tracks and components values (board-2)
- the same visual as board-2 but with just "the diagram" as it is on the card (board-3)
- the diagram transcribed from my statement
I hope it will be clear and easy to read...
* I add board-4 to be more clear... same side = side by side
    294.3 KB
    363 KB
    287.3 KB
    260 KB
    148 KB
Hi!
The scheme drawn by you is not entirely correct.
I have drawn the audio circuit diagram for you.
I'm sorry, I can't deal with this problem today anymore, I need to rest and calm down.
I have a doctor's appointment tomorrow. I have serious medical problems.
I recommend you to rest, relax, spend time with your family.
With a rested mind you will see things more clearly.
We are not robots.
    3.8 MB
Thank you micolas.
Sorry for your medical problems... Yes, life is tuff sometimes and we got to take care of ourselves !
Have a nice evening :)(y)
Hi
I've rebuild the audio circuit on a new board > a "bread-board" (I love bb) with the same values.
I cut the high-pass board (easier way to do) and conneted it to the audio board with wires.
The mic is now functionnal again, but I lost 4dB regarding to the "original" one (...)
I measured the 2 transformer (not connected) and I found :
- Original : 129Ω / 49Ω
- Monacor (E wiring) : 323Ω / 63Ω
A special thanks to @micolas for helping me +++ ! ;)
    624.4 KB
    499.9 KB
    517.1 KB
Hi
You put R3=R4=6.8k or
R3=R4=2.2kk ?
Is it the way we wired the transformer that makes the mic loose 4dB ??? differences in K170 or SA1015 ?
