SE Electronics Z3300a
This is the waveform of audio I recorded yesterday with the modified mic
and same part with the original one
    27.2 KB
    54.7 KB
    407.6 KB
    466.5 KB
Connect the microphone to the sound card. In your DAW you have an oscilloscope or you install an Osciloscope plugin.
You replace the capsule with a capacitor of 60...70 pF.
You inject a 1kHZ signal through a 470...1000pF capacitor into the C8/R12 junction, from the phone. You increase the injected signal until the sinusoid starts to limit, to clip.
Adjust the VR until the limitation disappears and the sine wave is again symmetrical and perfect. Increase the volume of the injected signal again and repeat the procedure. Make sure that the + and - branches of the sinusoid are symmetrical, limit at the same level.
Repeat the procedure until you can no longer stop limiting, but limit symmetrically.
Reduce the volume of the input signal until the limitation disappears. The sinusoid must be symmetrical, perfect.
2. Another more unscientific method.
It injects complex music with many frequencies at the same point. Listen in studio headphones. Turn up the volume until you hear distortion. Adjust the VR until it sounds clean. Increase the input volume further and repeat the procedure, several times, until the VR can no longer be adjusted to hear clearly without distortion.
Do all this in small steps, patiently and carefully.
You can disconnect the output (drain) of jFET from capacitors C5 C6
If you do not have an android phone, with the frequency generator application installed, record a file of several minutes of 1kHz, sinusoidal, at high volume, -1dB, clean, without distortion. And injects signal from the laptop.
1.
Ok thank you for "the procedure" (I had alreday a tone generator on my smartphone)
I have 47pF in stock (no 60 > 70pF)
So I inject a signal R12/C8 trhu a 680pF or 1000pF
You can disconnect the output (drain) of jFET from capacitors C5 C6 : You mean I go straight from drain to SA1015 base without capa ?
sorry, I was thinking of the oscilloscope method connected immediately after the jFET.
Ignore this with capacitors decoupling.
Hum... so 1kHz signal thru 680pF to R12/C8 junction ? (caps disconnected of course)
PS : I have a mini-jack stéréo (wired in asymetrical) with already 2,2uF soldered ? Is it Ok ?
    970.4 KB
Hi Micolas, like yesterday, it's late again... 19h30 > I'm going back to my family...
Anyway this has been a good day for the SC1100 project because I finaly made it working !
I think I'm gonna put the original Tr back before biasing the Fet because you told me it was a good quality one and also because I'd like the 2 mics to sound the same... and then I will bias the 2 mics as your "protocle"
