it's very easyYes my friend had just bought the same one from Ali ! but I never used a scope in my entire life... maybe it's not so complicated to learn how to use it ?
(I put one item "in my basket" )
like a breeze
Does it do "send & return" ? I mean it generates a sine-wave and analyse it ?it's very easy
like a breeze
For this price?Does it do "send & return" ? I mean it generates a sine-wave and analyse it ?
gain and low frequency response are reducedBut so, what happens if you don't decouple the source resistor ? you loose gain but you get "less distorsion" and more linear signal ?
so it's not the same as tubes...gain and low frequency response are lost
I have this Waves InPhase plug-in installed in my Logic ProAdjust the VR until the limitation disappears and the sine wave is again symmetrical and perfect. Increase the volume of the injected signal again and repeat the procedure. Make sure that the + and - branches of the sinusoid are symmetrical, limit at the same level.
Did you make simultaneous recordings with the stock microphone and the modified one, before changing the capsules, transformer, etc.?With the proper bias the level has leveled down and fits now the original mic
on the picts, one can see that without any R after the R source 1,8KΩ the signal has more neg. than pos. / with the R 6,8KΩ the signal seems equal (but with less gain)
So now, this modifyed mic's electronic is done : will install the Arienne k47-flat (but first I got to work on the original one > change the transformer & bias the Fet)
Of course I will record with the pair (in omni & cardio) before changing the capsules...
As I told you, going from a transformer ratio of 2:1 to 1.5:1 will increase the output level.Hi !
I tried to replace the original transformer but it does not work and it must short circuit because I lose my supply voltages coming from 48v...
So I replaced the Monacor wired according to diagram "A" and here instead of -6dB compared to the original microphone I have +4dB (i.e. a gap of 10dB!)
The diagnosis was correct:Hi !
measure the voltages in the important points, including the transistors, after BIAS ing, to be able to compare them with the originalWhat do you think of my Fet biasing ? Does it seem ok for you ?
As I said I rejoigned the original gain level but the signal wave is clean with the add of 6,8KΩ
After each change or adjustment, you have to make new measurements, tests, records, comparisons, etc.,to make observations and analyzemeasure the voltages in the important points, including the transistors, after BIAS ing, to be able to compare them with the original
