YesThere, that wasn't so difficult now, was it?
So that's with both transistors on the DC/DC board removed, right?
Yeah, you're right, but what could have been the damage ??? I think I'll be able to put back the transistors (if they didn't suffer)Hooray for "blind" advice...![]()
One or the other but not me !Zero f**ks given during assembly? And/or the previous owner "took a look" very very carelessly...
and suddenly it gave up with crackling noise (see the spectrum I recorded)
I opened the XLR to measure :
mic connected : 1,96v btw pins 2 and 1 / mic disconnected : 44,24v btw pins 2 and 1
No I didn't replace them yet, just push them appart to end this possible (surely) short-circuit... but since it's the same situation I believe something is damaged... (remember the 2 tr are desoldered)Is that NOW, after you replaced those damaged wires?
When I discovered that the circuit was fed by only 1,9v I stopped expecting any sound... and localize (or so) taht the problem had to do with voltage alimentationSERIOUSLY???![]()
Well, how the hell do you expect to get any audio, with the capsule not getting any voltage?![]()
No but there are pushed appart from each other (like on the pict) so it'sHave you replaced those two damaged wires yet?
