Serious transformer!
MartyMart
Berlin for a while
... OK not as big as the ones they move on a 128 wheel truck but it's VERY nicely done :)
Arrived this morning with Boss TU12 Tuner for scale:
It's 9.5cm across and 6.5cm high, weighs almost 3 kilos !!
( for a PM670 .... with BALLS!! )
MicDaddy said:
Holy crap!  Is it possible for others to order using this # R3-0245-0001 ?  Will they ship to the USA?
You shouldn't have any issues with over working that puppy.  8)
I would think that if you used that code and quote the specs written on the side, no problem.
Could be an expensive "post" stateside though at almost three kilos !!
The cost was very reasonable and the quality is top notch, it's my first ever "made to order" item
in my life !!
I just hope the 3U case I am planning to use, is up to the challenge !!
MM.
