I’m researching State Variable parametrics and looking at how different designs approach shelving. Post examples!
Main questions:
1. Other than the PQ1549, what designs use the SVF to produce a shelving response from the cut/boost amp?
2. Has anyone directly compared the sound of a Sallen & Key shelf with an SVF-derived shelf? Q of the SVF would have to be .5 for an apples-to-apples evaluation.
Thoughts on two very different approaches:
Net EQ -
Shelves are single pole SK, which entirely replace the SVF when engaged.
Anybody know why Porter chose this route? I believe noise floor was a consideration, but also: His bell Qs range from 1 to 3, and he relies on the input resistor & BP feedback resistor for extra attenuation for better headroom within the filter, so I’m guessing that setting the SVF to an even lower Q and then deriving a shelf from it on the back end would have been more complex than the simple SK substitution.
Calrec PQ1549 -
Low shelf achieved by shorting the LP integrator’s feedback cap, which appears to A) negate the feed from the BP integrator and B) silence the feed back to the HP mixer, thus turning the BP integrator into a LP integrator for only the original signal (whew). That single pole low-passed audio is delivered to the cut/boost mixers via the very same BP output. High shelf seems to be achieved by tapping the HP output, correcting phase, and sending that high-passed audio into the cut/boost mixers instead of the BP output. [EDIT: Like above, the LP integrator is negated by a direct tie from output to NI input.] Both shelving switches also lock the filter on its lowest Q setting (which I haven’t calc’d) but would love to know).
That’s not very complicated. You don’t need an extra pot section controlling a separate filter, nor an extra op amp. It’s also less complicated than summing outputs, as is commonly mentioned (i.e. LP+BP or HP+BP). I have not yet seen a schematic with SVF outputs summed, but maybe that’s because when people mention it, they’re talking about a series application (???), and we generally don’t use SVFs in series. Does anyone have an example of this handy?
Main questions:
Net EQ -
Calrec PQ1549 -
