- Joined
- Mar 7, 2021
- Messages
- 22
Hi Tinn.I use two ADM770 Modules as a micpre since 1999. I cut off the fader and use the cue 2 pot as output level control instead.
Also I changed the Input Pad from 60dB to 20 dB (switchable with the Line switch).
I acquired a pair of adm 1500 skittle eq’s I just racked up.
I’m starting to reverse engineer them to get them up and running.
You wouldn’t have a schematic of the eq section would you. Mine looks almost the same as yours except the transformer layout is different. Looks like the same transformers, just physically located different. I haven’t been able to find any documentation on them. None of the 770 schematics I’ve seen show anything but a very basic block diagram of the eq section.
Any help would be appreciated.
