radardoug said:
Well, they have reel to reels, someone must maintain them. They could flog off one of those guitars to pay the bill!
Hey radardoug,
Thanks for the questions. I am, in fact, a highly technical person. I am also not too prideful to enter an arena in which I’m not well-versed and take a little heat in order to learn new fields, which is what I’m doing here. As scott noticed, I’m a studio owner, producer/engineer, mixer, mastering engineer, songwriter and a multi-instrumentalist. I’ve interconnected and created multiple studios over the years, and design and build various transformer boxes for myself and others. I’m also a computer programmer and an avid cook lol. I take all of this to the max of my abilities and am a constant learner.
So again, I am here to learn, and learning implies not knowing all. My fundamental electronics knowledge is lacking (I believe I wrote this in my first post here but maybe not).
I do understand the concept of that dropper resistor as it applies in series, however, I didn’t know if it would affect the other power input from the battery with something like a load concern. I was shooting in the dark here based off of what you’d said and trying to solve an issue. Apologies for being pedantic - I’ll improve as I progress.
Good news is that I tried other wallworts and after metering them, they almost all output 9.4v. So I plugged one of those in and voila, compression now works! Sounds lovely. If you want to hear a cool snippet of this and another old Shure comp in action, here’s an instagram post: https://www.instagram.com/p/Bp7dEoABXyk/?utm_source=ig_share_sheet&igshid=30omypd9vh60
To complete this saga, I’ll just say that I did learn that the wrong amounts of power supplied can still pass signal, but render some components (I’d assume transistors at least) unusable for their designed purposes. I had thought perhaps that it would only use the amount of power it needed but clearly this is incorrect logic. So now the only issue is that the mic output isn’t working. But the aux line out is working, and sounds great.
Thank you all very much for your help!
Mark
