radiance
If you want sends than..yes.
macwanj said:Nice job radiance! Just one question though... where did you get the PCB made? Must have been expensive...did you do it on 2 or 4 layers? I'm building some thing similar right now using 990s with a DC servo for 48 channels...Any tips on pcb layout would be appreciated.
guitarguy12387 said:Ok. Looking back at the first page (the summing schem). Whats the purpose of the 510ohm R from the non-inverting input of the 990 to ground? Is that compensating for input offset current of the amp? If so... why not one on the opa604/opa134?
guitarguy12387 said:Secondly, whats the function of the opa604/opa134 even? I thought the DOA was providing the makeup gain?
macwanj said:Hey radiance,
I'm still trying to figureout the best way to do my pcb layout and I was hoping you could help me out by answering a few questions. First off, what did you have on your 2 pcbs? I'm assuming one had all the differential inputs and outputs and amplifiers and the other bigger pcb had the summing amp, vu buffers pots etc.
macwanj said:how did you do your power and grounds? Did you use traces or segmented planes?
macwanj said:Did you use a thick copper bar for the ground buss bar
macwanj said:and thick traces for the summing bus and ground bus traces?
Davo said:is the THAT 12xx designed to handle "line" inputs, or will it do just fine with lower impedances? (I know, it's called a "line" receiver, but I just don't know hehe)
radiance said:I guess it's designed for line imputs hence the namebut you can check the data sheet here
http://www.thatcorp.com/datashts/1240data.pdf
What exactly are you trying to achieve with your mixer outputs? I'm not sure I understoot it correctly...
synthetic said:Hello, I'm another beginner looking at active summing mixers. Mine will be based on the NYDave 16-channel passive mixer into the Forssel summing amp 2, though possibly using OP275 instead of 990-based op amp at least at first. (The NYDave schematic seems to be hard to find, so let me know if I should upload it anywhere.)
I have a general question about the resistor tolerances. I've been thinking about using 0.1% resistors at least on the inputs so that imaging, etc. doesn't get messed up going through the mixer. Is this necessary or am I crazy?
synthetic said:Should I post to another thread? I didn't mean to hijack, but didn't want two separate active summing threads either.
