Hi Radiance,
Question for you on your input side.. have you had a look at your crosstalk performance? I built 16 channels of input using THAT1200, so the architecture is a little different, but maybe some of the same concerns. I've been seeing about 65db at 10k, which is OK but I think it could be better. I'm fairly positive that it has to do with the input side since if I remove all those components except for two channels, crosstalk improves to 80db.
So, I've been scratching my head about how to make it better, and perhaps it's as good as it gets but I'll pursue improving it until I'm convinced that I can't any more.
My thinking is that it's all the ref (pin 1) connections from each chip to the same ground plane. I can measure about 85k resistance between the input pins from one channel to the next. That makes perfect sense given the internals of the IC.
What I'm asking, I guess, is if you've been able to achieve anything better with your design, and if so then I may want to pick your brain a little about how you did so.
Thanks! And excellent work on this, hope you're enjoying it.
Brian
