When the detector is cap coupled won't there be have some charging effects going on with C1 & C2. What happens if steady sine wave is fed to the sidechain? Am I talking nonsense? I'll have to fire up the simulator when I get home because I don't have the mental capacity to think about it.
My worry is that if the sidechain is fed constant signal the CV won't be constant. There will be a peak first but steady signal won't sustain it. I'll check it out with spice when I get home from work.And I was about to use it like that on your vari
Do you mean diode resistance having effect on time constant and/or filter ?
What is the source of this "document"? I see two major interrogations there.Thanks for clarifying....
I read an interesting interview about Gyraf s G24... As I understand this device has a unique way to drive 2 cascade/series sidechian...
With all respect due to gyraf, I'm not convinced by the +/- 90° thing.They do using the mono listen compatibility c. Room feature of old console
Full article... Translate from German...
On green is the sidechain output with trasformer input and the blue line is where the transformer is replaced with the circuit from post #65.I'll check it out with spice when I get home from work.
Can you post the PRR vari mu schematic?The PRR vari has an opamp between cap and diode. There bias goes thru that opamp. So would a buffer make any difference or does this mean the PRR has the same issue ?
Thanks for comparison and infosOn green is the sidechain output with trasformer input and the blue line is where the transformer is replaced with the circuit from post #65.
The proposed transistor circuit has an output Z of 33k, when an opamp has near-zero. It's bound to make a difference.The PRR vari has an opamp between cap and diode. There bias goes thru that opamp. So would a buffer make any difference or does this mean the PRR has the same issue ?
Full of scribbles. But I drew oneCan you post the PRR vari mu schematic?
