Tim Campbell
Early M7's had a hole drilled from the edge to one of the blind holes as a vent
Now that's interesting! I've seen some relatively early m7s but not the pre u47 ones. I can see why they stopped. Seems like it would need to be thin.Early M7's had a hole drilled from the edge to one of the blind holes as a vent
My M7 i have from Dale (or cathedral pipes, not sure) has this type of hole.Now that's interesting! I've seen some relatively early m7s but not the pre u47 ones. I can see why they stopped. Seems like it would need to be thin.
Someone I know has a really really early M7. Serial number is early double digits. 14? 16? It sounds horrible. The holes are noticeably too shallow IIRC. The M7 is one of those capsules where the early serial number preference common among collectors definitely doesn't pan out. Early M7s are awful, reskinned or not. It's like playing the lottery.
They charged nitrocellulose film with 60 or 100 volts of static electricity? Good Lord.The earliest Neumann capsules were also designed around collodian as the diaphragm material, not pvc. I think this was true with the earliest M7 as well but maybe it was just the stuff prior.
Early Neumann capsules had enough failures that in that era NWDR had approved Hiller, Joachim Wetzel, and maybe others, for refurbishing capsules with new diaphragms.They charged nitrocellulose film with 60 or 100 volts of static electricity? Good Lord.
This spacer is very important and really hard to find, thanks Arienne.Things are a bit of a frenzy right now. I'm reorganizing our entire manufacturing chain. Just finished the die for these, so I actually have something to offer in the meantime for anyone who needs them, since they are rare:
spacers for capacitance, plate distance etc, in 30mm screw ring diameter with neumann-style holes. They are precision die cut, not laser or water or micro CNC or anything that would cause the edges to curl or melt. They are completely uniform in thickness. This one is 50um, but I could probably customize thickness now that the dies are done. The hole cutout is 1.6mm, so keep in mind compatibility with your design. The visible marks are fog from the humidity of my hand.
Thanks! I made sure that it was correctly-dimensioned for most backplate variants out there and wouldn't overhang. The die and press are both pretty high-precision, so none of them clip the holes to the inner diameter so far. The film, too, was selected pretty carefully. My Mitutoyo cannot discern any variation from 50um over the full surface or spot-checking any of the portions with constant force. I don't have the equipment to actually examine the surface at my office, but my best guess is that the final spacers post-cut are consistent in thickness to about 2 HLB. Possibly overkill, but I wanted to make sure the screws w insulation could clear without getting caught on rough edges and the thickness consistency was a nice boon.This spacer is very important and really hard to find, thanks Arienne.
Does it make any sense to put a hole in the Flat 47 back diaphagm? I'm in no hurry to damage it. I'm just kind of curious about this.My M7 i have from Dale (or cathedral pipes, not sure) has this type of hole.
You can use a very small (and very sharp) needle to put a hole on the back diaphragm outside the gold to solve this problem, yes. I will replace it if you break it. Tighten the ring screws before you do it to make sure they can withstand the force without pulling downwards.Does it make any sense to put a hole in the Flat 47 back diaphagm? I'm in no hurry to damage it. I'm just kind of curious about this.
I'm really looking forward to when Ari releases the accurate K47 capsule. That would be an instant buy.
In high school I always burned my worn out guitar picks, being the little pyro that I was back then.Ever try putting a match to celuloid ?
very readily catches fire ,turns to back to carbon .
You don't have to shield the whole room, just avoid small dimension shield like headbasket. Small dimension shield will almost always affect
As a part of "r&d" Ari asked me to make a hole and see if it makes any difference in sound. I did so, and that is the capsule i kept and use as my favorite k47 to this date. However it did not make any change in the sound, not sure if it makes difference at high spl.Does it make any sense to put a hole in the Flat 47 back diaphagm? I'm in no hurry to damage it. I'm just kind of curious about this.
If it works who cares how fancy it looksQuickie Sidebar -- This brief, yet interesting exchange between Mr. @kingkorg and Mr. @Whoops concerning shielding during testing reminds me of the highly professional, super scientific temporary EMI/RFI shield, mini Faraday cage I made with a familiar household product whilst testing those low cost Chinese condenser circuit boards. (see photo) Don't laugh - it worked well and was a super down and dirty on-off-on again bit of test gear! One does what one can with what one has, although I am confident it may have worked better had it not been removed from my last pan of lasagna . . .
Happy trails, y'all. Now, back to the regular program. James
It definitely does, and it makes the capsule way harder to clean and restore decades down the line, but not moreso than any vintage neumann with the same issue. It's up to you.As a part of "r&d" Ari asked me to make a hole and see if it makes any difference in sound. I did so, and that is the capsule i kept and use as my favorite k47 to this date. However it did not make any change in the sound, not sure if it makes difference at high spl.
I wouldn't personally do it again as it makes the capsule vulnerable when it comes to humidity and dirt.
Your Flat 47 is a excellent capsule for taming the "brighter"47 Fet circuitry. Just awesome imo in this circuit.You want a little bit more air at 10k? I might be able to do that. Let me check to see how the k47 reacts to me messing around with the plate
