Soliloqueen's k87(k67) and k47 capsules
I have a prototype Arienne Audio K87 V2 in an 87 clone mic and I find it to be ridiculously great. I've used this mic on a TON of bookings the last 3 weeks and it's just perfect on everything. I couldn't be happier with it.
I have no doubt this capsule will blow your socks off when you get one.
EDIT: Attached is sample from part a read from a commercial I voiced for 3 different US Senators, done on the AA K87 v2.
View attachment K87v2-sample.wav
When do they plan on going on sale to the public?
some caveats: the engraving probably won't stay. the silicone wire they had in stock at the outlet in these colors was too thick, will source thinner ones for the production run. The rings are also upside-down. long story. The machine shop also pulled back a bit on the groove around the electrode surface for the very first batch since they're still testing what's feasible at volume:
which i expected. Still, it sounded exactly as intended once we cobbled it together, so no harm done. wordsushi's is the first ever assembled prototype and has a higher capacitance and different tension. This is the first that has all of the "final" technicals locked in so I'm excited to show you guys!
These are still in R&D right now.
Si how does this V2 compare to V1, in what do they differ? If V2 is much better/closer I wouldn't mind getting one even If I just got V1 😁
Will try out V2 for sure but I could happily live with V1.
By the way: clips 1 and 3 I uploaded are the Neumann U87Ai, 2 and 4 the D67 with Ariennes K87 capsule.
