I'm modifying my tube guitar amplifier with an adjustable Bias Pot instead of having fixed resistor values.
I used an CTS 10K bias Pot, and adjusted the resistor values on the circuit so that I got a voltage range with the Bias pot from -44V to -58VDC
I schematic of the Bias supply circuit with these mods is attached, new resistor values in RED.
The stock schematic of the amplifier is here:
http://bolt60.no.sapo.pt/documents/bolt60/Bolt60%20-%20Schematic.jpg
The amplifier was working before this mods,
but now although I have negative bias voltage I cant measure any Cathode current on the 6L6 tubes, it reads zero current. Also the theres no output sound going to the speaker. Tubes Light up and the plate voltage is 497V.
I'm using this device to measure the Cathode Current:
http://www.rig-talk.com/forum/download/file.php?id=49481&mode=view
the device works properly as Im able to use it perfectly with other amps, also used it with this amp before.
The 6L6GC tubes were working before the mods, I also replaced them for a fesh pair of new working 6L6 GC and there's still no cathode current reading or output sound.
Does anyone know what might be causing this?
thanks for your help
