In this case, there must be some leakage current out of the gate of the meter FET. Perhaps a faulty or fake jfet?
They should be both linear. I don´t know if there is even a 4m7 LOG available.Thanks for the reply Jacob, my meter can't handle it and I think I'll fit a driver circuit.
I also wanted to ask you for the ATTACK and RELEASE potentiometers if they were logarithmic or linear as in the BOM it is reported linear, while in the logarithmic layout. Thank you in advance.
Hi jakob! Yes I was waiting for a week for new ones. This time I ordered some directly from banzai-music berlin. bf245a and 2n5457. 0,80€. Both stilll show this problem. FIRST, am I right that when I pull out the one before the meter and the problem is gone it MUST be the driver circuit, right?!In this case, there must be some leakage current out of the gate of the meter FET. Perhaps a faulty or fake jfet?
Small is a little relative. With the old bf245 there is NO movement at all. With the new ones the GR when everything is calibrated correctly ( tracking!), is moving 10db or more so all over the whole VU scale. This can not be right. Also it is showing this when compression is off and then the output is droping when turning the release.Ummm I'm not sure that this has been mentioned... All correctly functioning 1176 will show a small shift in the 0dB point when reading GR and the release pot is rotated from CW to CCW. It's normal
Thank you Jakob for your support. Yes I saw these SMD ones. At ebay I saw some NOS. But who knows if this is true. But imagine; I have over 20 FETs here right now from different sources and none of them performs like the two old ones I soldered out from a unit which is 8 years old. I didn´t expect that and was swaping Tantals, diodes and caps like crazy.Thanks for reporting back, TimPanic
At this time it seems really tricky to source genuine jfet transistors in TO-92 housing - market is flooded with fakery.
Perhaps try to find a SMD substitution (these seem to be faked much less), and mount by attaching wires?
/Jakob E.
Okay, that´s precise info and exactly the behavior of the old bf245 I have here.I have seen needle movement in some "real" rev#F's - but only just moving, like a needle-width or so..
I check this out. Damn, I just ordered some Bs and Cs cause I had no luck with the As.referring to schematic: http://gyraf.dk/gy_pd/1176/1176sch.gif
I think it must be drain-to-gate leakage in the "meter" jfet Q10
can you rule out contamination on the PCB in the area?
perhaps the jfet dosen't like the full extent of what is left of the +30/-10V after R49 (or R52). What supply voltage do you have at IC1/Pin7, its positive supply pin? Maybe try making R49 (4K3) larger until you end up having only e.g. +10V here, this would result in lower tension across the jfet
btw, you'll probably preferably want BF245A, not C
Totally get you but it´s just that it´s also droping the output level which is a little annoying.for meter circuit, it's probably not important what sort of fet you use - meter precision is a concern very low on the list![]()
Jakob, you are the man. Amazing! This really made it. I kneel. I measured around 17 volt at pin 7. I soldered out the 4k3 resistor and put a 10k pot there to bring the voltage down to 10V at Pin 7 and guess what the needle stays at zero like a brick no matter the release knob is turned. I measure 6k4 at the pot now.yeah, we don't want audio affected - also because this reduction of gain comes with distortion cost
Try lowering the meter-fet voltage as suggested above?
I am going to revive this thread as I am a bit stuck working on a Purple Audio MC76 (stock so non DIY).
when I got it the unit was stuck in max attenuation so I could only get max 6dB out of it.
massive battery leakage around Q1. cleaned all of that and (momentarely) disconnected the active circuitry.
stripped the PCB on the preamp-gain reduction circuit, scrubbed and cleaned. recapped almost every where reinstated the FETs and its' working. I can now line it up and so on, however....
I am having the same problem as everybody else here, but here is what I have found.
-I have disconnected the sidechain Diodes (CR2+CR3) as well as C19 and C20
-disconnected C 27 ( on the attack pot) AND disconnected the attack pot from the release pot.
-removed C18 and C814
-removed C21 and C813
-removed C17
and still if I measure at the release pot where it connects onto the PCB basically at R7/C22 I get a DC voltage swing between having the release pot CW or CCW.
(caps replaced so far, C1, C28+C817,C2,C5,C600+C816, C22, C3 and C6)
when Release is full CW I get 0.222 VDC at the gate of Q1
when Release is fully CCW I get 0.1543 VDC at the gate of Q1.
why is this DC getting through C3 and C6 first of and secondly where is it coming from? I have replaced C3 and C6 with ceramics (that is all I had) but even if I remove them it's still happening. if I remove C22 I get pretty much no DC swing.
so it looks like is coming from the Release pot attack pot combo?
any ideas/pointers/previous experience?
many thanks
