Андрій Чубака
- Joined
- Apr 10, 2023
- Messages
- 110
but I still not sure need I am this or not? Trimpot here is 10k I guessDid you omit and install jumper in position of D8 and Trimpot of voltage multiplier board?
i know all this but when chip is broke down on psb every time put new and expencive chip every time is not solution. Also you never can be sure have you original chip or not. Now almost everywhere copies from china one is with more better quality other one is just very poor quality. In this case I do all best what I can. and first of all I must fix pсb problems.I'm not really sure what you are doing here. You absolutely have to use the original Op Amp as intended. Tl072 won't work for various reasons. Also you can not drop the value of 1Gig resistor to Mohm range. Follow the original instructions and the mic will work. It doesn't get any cheaper or simpler then the original schematic.
You absolutely can by ordering from something like Mouser. Also you can check quiescent current to be sure, and drive capabilities. You are wasting your time with TL072, if nothing else noise will be terrible, THD, and drive capabilities. Have you checked current and operating voltages with the TL072? If your component source is sketchy, you can't be even sure it's TL072.i know all this but when chip is broke down on psb every time put new and expencive chip every time is not solution. Also you never can be sure have you original chip or not. Now almost everywhere copies from china one is with more better quality other one is just very poor quality. In this case I do all best what I can. and first of all I must fix psb problems.
