Why not? It allows finer balance of current in the OT. However, it is not a guarantee that the output halves will be more precisely matched. In conclusion, it does not free you of using matched pairs.kepeb said:I just wanted separate adjustable bias...
Is it 53Vac or 53Vdc after rectification/smoothing? If it is 53Vac, it means the rectified voltage will be about 70V.the PTX i used is mojo 762ex (export) fender replacement. the bias winding states 53v on the diagram i found.
You just need to duplicate the 10k series resistor, the 50k pot and whatever padding resistor you may want to put in series with the pot.Abbey says the published design will fail, has excess pot dissipation and suggests a route for a corrected single bias (maybe easier to work out with known ptx above) but not how to dual this.
This is not likely, because the xfmr specs says 53Vac, so you will get more.so, lets assume i'm getting exactly 53v on the bias.
Correct; the more negative the grids, the less current is drawn in the anode.from what i can find on EL34 biasing the recommended is -38v, as weber suggests 'starting' at about -55v can i also assume a more negative voltage/more resistance to ground, will be less current draw?
You have to read the graphs in the spec sheet. There's always a graph that shows Ia vs. Vg, generally with different anode voltages.how do i determine the current here?
No; the bias voltage goes to the grids but there is no current flowing (or so little it is negligible).If the current (which from what i understand but is not well defined) will be about 20mA from bias to tube (each tube in push pull?), then this is 40mA to the tube grid. how does this stress the pot?
Even if there was current flowing to the grids, Kirschoff's law would still make current flow to the rest of the circuit.acting as a voltage divider the current would be going to the tube only and not through the remaining trim value, which will just determine a reference point for voltage?
With 400V B+, the bias voltage to cut-off the EL34 (i.e. the bias voltage for zero anode current) is about 55V. It is good practice to allow the possibility to put the tubes in cut-off, that means you must make sure the bias voltage can reach 55V. The recommended bias of 38V should be with the pot more or less at mid-position. The data sheet shows there is no need to make the bias going below 20V. You may want to do the maths, or experiment.
Please note however, that guitar amps tend to run at lower quiescent current, so the actual bias voltage would be a tad higher.
There may be a discrepancy in the Mojo specs. The M762EX xfmr is supposed to be adequate for the AB763 circuit, but on the AB763, the bias smoothing cap is rated at only 50V. With a 53V winding, this cap will be seriously stressed, although there's a 470R drop resistor in the ac branch that drops about 10-12V.
