Because for me the mixer is part of my instrument, and I want to record exactly the same mix as on the main LR out but split into separate tracks for easier editing and post processing.Hi, why did you do the direct outs Post fader and not Pre-Fader?
With Post Fader when you are mixing the live gig you will constantly change the record levels each time you move a fader
The schematics for the mixer is available on the net. I simply tapped the audio where it enters the pan pots. I used two 470 ohm resistors to hot and between GND and cold (impedance balanced). Could use lower values but had a bunch of these.. Made a PCB with an IDC connector, resistors, and the DB-25 connector. Happy to share the gerbers if anyone interested.Cool! Do you got schematics or more close up pictures?
