if anybody's interested i could whip up a self etch for one of the preamps. And to be honest i like PPA's design the best since it offers balanced out. But we could also do the the 2 stage ssl one with impedance balanced out so we won't need the rev log pot.
so which one does everybody like the best to have a self etch pcb made.
This is what I consider my first successful layout, comments welcome.
I took out what looked like a pad function to me and added a THAT 1646 output driver.
Was thinking about taking off the footprint for the 250K LOG POT and just putting in some pads.
Here is the second revision, You'll be able to see the changes.
This has not been tested so if there is something wrong let me know and I can fix the layout. You will have to reverse the copper side image, that has not been done.
Ah, and the 2 pin molex gives you the option to add a pot or make a switch much like the 9K board.
Just finished my layout...
SSL E pre / Line in / LMC
with DI, pad, +48V, phase invert
separate PSU with +/-18V, +48V, +12V
It'll be my first 2 layer etch, so this beta is probably gonna take a little time to get right.
The 'E' preamps used a pot with a push/pull switch to engage phantom, and a 20dB pad switch, below the red polarity button. they were available as transformer (Jensen JE-115K-E) on the 82E01 board, or with an LM394 matched-pair transformerless input on the later 82E149 version.
The 'G' preamps had switched gain, and no push/pull for phantom, so the pad switch was sacrificed, and the range of the preamp extended downwards. the board number was 82E249 if i recall correctly.
Hot tip: On each version, if you ever rack a board up, use the polarity-reverse circuit to generate an opposing signal for a 'free' differential ('balanced') output.
