Well,
it has been a while, but a week ago I thought it was time to be working on the 552 compressor again, haha. It has been sitting in a closet in an open box for more than a year, hahaha.
But now ..... :
I've got some additional info : It's possible to power the 552 from the GSSL board.
The post VCA send will be the output of the module.
The following things will be removed :
the external input, and the post VCA circuitry including tone and TB insert, and mono output.
There are just a few simple things that need to be done to the 552 boards , then it's possible to take out the logic part, so you won't be needing the -25v line anymore.
That means, that you can use the GSSL +/-15 volt PSU part for powering the 552 module, by changing the 7815 and 7915 to 7818 and 7918 (and use a transformer with a dual 18v secondary.)
Here's how to do it :
The mods must be made on both boards.
Summing stage :
-remove TR1, TR3, TR7, and TR9.
-remove TR2 and TR4, jumper source to drain. (pins 2 and 1).
That’s easy, huh ?
Stuff that’s not in use, best is to take them out to reduce powerconsumption. Except for a few hybrid chips, all are socketed:
T85052 board :
Hybrid chips : H6, H7, H8 , H9, H10, H11, H12
Demux chips : IC 7, 8,9,10,11,12,13, 14, 17,
Plus on the T85152 board :
Audio chips : IC 7,8,9, 15, 16
Hybrid chips : H6, H7, H8, H9, H10
The audiobalancing chips are valuable, so, keep them as spare. (85501 and 85502). The other hybrids are practically worthless.
