TillM
Whoops said:If you used the correct Pot for gain I don't believe it's the gain pot, it's probably something in the circuit that is wrong.
It could be a lot of different things impossible to know at a distance.
Before anything you should:
-Check all Electrolytic caps values and Correct placement. They are polarized + and - are on the correct holes?
- Check all resistor values
- Check all capacitor values
- Check MAT02 placement, is the orientation correct
- Check all IC's Orientation
- Check all solder joints and check for possible solder bridges
- Measure the voltages across each IC and transistor Pins, do a voltage chart, show us
Do you have a friend with electronics knowledge that could help you?
Tomorrow I go to a friend.
He is electrician and also has a oscilloscope.
One thing came in my mind.
For the Second Build I use the Switches from the BOM.
For the First build I use Switches from my local Hardware shop.
They only have 20v. From the BOM they have 250v.
Maybe this is the fault.
Thanks for your help.
