SSL 9K & 4K (E Series) 500 / 51X NEW BOARDS Mic Pre Thread 2011
Ricardus
WILL SOLDER FOR FOOD
No longer in NY and below the Mason Dixon line.
But now i recognize another Problem. The low cut pot sounds not like it cuts frequencies where it should do.
By turning cw it Sounds like some kind of sweep eq. It seems to boost the frequencies. I dont get it. Very Strange.
I think that i populated Everything the Right why. So i dont Know
Did you calibrate the HPF? It needs to be calibrated to work properly.
There are two pots on the board. One is to properly shape the "knee" of the filter, and the other is to gain match it to the volume when the HPF is switched off.
So if the knee is currently shaped with a peak (as opposed to being flat) the filter will cut lows but also raise the frequencies right at the point where the cutoff frequency is set.
If you're using the boards from PCB Grinder then you also need to fix the out of phase output issue. It involves cutting two PCB traces and running two jumpers.
frejo89
germany
Youre just so great- thank you! Completely forgot that !!
Concerning the out of Phase output issue. Mine ist from pcbgrinder. I dont now the exactly Revision. But it Shows something like „bruno2000“
I ordered it in october 22
frejo89
germany
Can you Tell me How to fix this issue ? When my pcb is the affected one ? :)
frejo89
germany
Which issue are you talking about?
Sorry. You were talking about These issue to fix on pcb:
„If you're using the boards from PCB Grinder then you also need to fix the out of phase output issue. It involves cutting two PCB traces and running two jumpers“
So were do i have to cut the traces and Running to Jumpers :)
frejo89
germany
There is a drawing on this thread somewhere. I have the drawing on my computer at home so I will post it later.
What about the HPF calibration. Did you already do it?
I already did the calibration. Its really a pleasure right now - I like it.
Ok - no stress to yourself. Feel free to post later, I will have a look at this.
Goog night!
Ricardus
Goog night!
Here is the PDF. This view is from the component side of the board but the traces that need to be cut and the jumpers all go on the back side of the board.
  • SSL 9000 phase fix.pdf
frejo89
germany
Hey together. Still stoked about my SSL 9k.
Another question :
Is there some mod of line in for the front? Or no chance to do this for having line jack in front in addition?
