Harpo
[quote author="3nity"]is anyone running the Keith psu on a 30VCT transformer?
that gives a +41 as phantom... i'd like to reach 48V perfectly...[/quote]
No need to change the resistors. With a 15-0-15V transformer your 41V seems the max.voltage you can pull out of this doubler curcuit (2* (15VAC * 1,414 -0.6V diode drop)=41.22V, may vary depending on line voltage). You'll either need a 40VCT transformer (as labled in schematic), using the KPS-1 pcb or a voltage trippler to get your min.51V raw DC before your regulator.
