geetar_king said:
wired up a channel last night but didn't have much time to play around with it. it's passing audio! phew! still some work to do with the blend board. man this thing really compresses though when it kicks in! i put it on a snare track and i could almost here my neighbor's microwave coming through in the background
anyone know what the best way is to set the bias trimpot for the FET?
When I made this post, I now realize that the first sentence may be misleading; I was using a mental shorthand when I wrote, it the instructions may not be clear...
Clarifications are underlined and in italics;
Looking on the schematic, you would remove jump 2 so that when you apply a test audio signal the side chain is not trying to compress.
On most FET type compressor/limiters, you first want to adjust the trimpot
so the gain through the circuit is at maximum i.e. no reduction in gain from the fet.
apply a tone signal to the input (1kHZ will do), and monitor the output with a device that can read dB out. adjust the gain of the signal so it high enough to read on the output of U1B, but not high enough to distort.
Adjust the bias pot so you have maximum gain through the circuit. Turning it one way will reduce it; the other will increase. Wait for the gain to settle. Make sure you can't get any more gain turning the pot.
NOW, slowly turn the bias trim pot until the output of U1B drops by 1dB. This may take a little effort as the bias circuit has a long time constant in this circuit. What this does, is turn the FET channel on so it's always conducting whether you are compressing or not. This reduces distortion.
return the jump 2 to it's place, remove the test signal and apply audio.
Compress and enjoy.
