Thanks Igor - that's what I had assumed, but when I looked up farad on wikipedia it said:Igor said:Hi Ben, yes, all these caps are 100uF. In any case, 224=220 nf, 100u=100U=100m=100microfarad.
and then on this calculator:1F = 1000 mF = 1,000,000 μF = 1,000,000,000 nF = 1,000,000,000,000 pF
1μF = 1,000 nF = 1,000,000 pF
To connect the tb combiner to CRM, use tb_on terminal on CRM audio pcb. They have same pinout.
100r resistors usen in case something shorted from outside, just to save expensive A6833 relay driver.
This is the answer1.6Vac at+/-15Vdc
