Veryveryfamous
Member
- Joined
- Feb 23, 2011
- Messages
- 7
I'm in the middle of a PCB design project and I'd love to hear some thoughts on approaches to grounding. This PCB is for a synthesizer so it has some things that are more in the digital realm and draw a bit of current (gate signals and status LEDs that switch pretty quickly) and some things that are more analog (input preamps and VCAs).
To keep switching noise from the digital elements from leaking into sensitive analog areas, my strategy has been to run separate ground paths to digital and analog areas which lead back to the power supply where they connect in a star ground.
On the other hand, on many PCBs I see, there is just one big ground pour all over the board which I assume has the benefits of being a super low resistance path to ground and some sort of beneficial shielding (coupling?) affect on the other paths it runs along (approaching the benefits of a whole ground plane layer).
When does it make more sense to run individual long and skinny ground paths out do different areas in a star ground and when is it better to just combine those ground paths into the big overall ground pour?
