ruairioflaherty said:Agreed no very heavy lifting here, but I could imagine a design using a few different parts.
It is pretty common these days to use canned solutions for input/out like THAT chip sets. Porter invested some effort as I recall in making an output driver that didn't suck. He didn't have the options we do today, to use simple solutions.
I have the THAT in/out chipsets in a few units here and they are indeed very fine sounding. In conceiving this new build as part of my dream chain I'm pretty certain I'd like it to be unbalanced. I have a couple of things on my side
- My chain is (and will be) short, 4 or 5 units in close proximity.
- Al source and load impedances are predictable (and easy to work with).
- the broad goal is to change the sound as little as possible when run flat.
Ruairi
I suspect there may be some confusion about cost/benefit in balanced interfaces.
Or perhaps I should ask, what do you have in mind for an unbalanced input?
The distinction "balanced" only means two signal lines with a differential receiver and similar source impedance to ground on both signal lines. Inexpensive "impedance" balanced sends using only one opamp are still "balanced" .
The distinction "un-balanced" only means that the two signal lines are not the same impedance to ground. There can be unbalanced two wire and 3 wire interfaces.
While most true active balanced inputs require two or three opamps, mainly to deliver the like termination impedance to both lines, you can make a single opamp differential input that performs very close to a true balanced input in all respects except same impedance to ground and therefore degraded noise rejection of CM noise picked up in long wire runs.
Lets not confuse "single ended" interfaces using a single audio line and shield, with perhaps unbalanced interfaces using differential receivers and 2 audio wires inside a shield.
I believe very strongly that single ended interfaces have no place in professional audio. Likewise full balanced interfaces are perhaps more than needed for typical short runs. IMO always use 3 circuit wiring (2 hots and ground), and differential receivers, even if just one opamp, and therefore technically unbalanced.
